bose radio bulbs
Jab215
Car: 2003 Nissan Pathfinder LE
Looking to find out what size bulb and how many for a 2003 pathfinder's bose system radio.
Jab215
I answered my own question. Anyone looking to replace the lights on this radio, unless ur very good at soldering i dont recommend trying to change the lights because its a special bulb thats sord of part of the circuit board behind the buttons.
Crockett
Car: 1999 Nissan Pathfinder LE
I am looking to replace the bulbs that have burnt out and have the same type unit that you have. The bulb base seems to be a surface mount type unit, which would need to be un-soldered and replaced with a new base and bulb, or just replace the bulb with the Micro Lamb #7219 12V 60mA from Radio Shack
Crockett
Try this link for what I have put together regarding the Bose button lights. You can definitely change them with minimal trouble assuming your radio has the same type bulbs. Mine are leaded bulbs, which are soldered on the other side of the board, not surface mount bulbs.
bose-radio-bulb-replacement-1999-nissan ... 04277.html
