How old is the battery?If it is the original battery I'd replace it. If the battery has vent caps you could check the specific gravity of each cell with a battery hydrometer. How is the alternator? With a digital voltmeter you should read about 14v across the battery terminals with the engine running. If you connect the digital multimeter in series from the positive battery terminal you can measure any draw from the battery with everything turned off. You can pull the fuze from the Bose if that is suspect?Jorgito wrote:I have an INFINITY 2003 sedan.After two days parked, the new battery goes flat. Dealer said it is the BOSE what may cause the problem as everything else seems OK.
Any one has the same problem solved? Thanks.Jorgito
Perhaps the problem is in your Infinity speakers and not your Infiniti automobile?Jorgito wrote:I have an INFINITY 2003 sedan.After two days parked, the new battery goes flat. Dealer said it is the BOSE what may cause the problem as everything else seems OK.
Glad to hear it!!Jorgito wrote:Finally, I changed the radio and now it seems OK. Thank you. Will contact you if needed. Jorgito
