rrack »
https://forums.nicoclub.com/rrack-u1705.html
Thu Jul 22, 2004 6:04 am
Similar problem cept the left front is now DOA on my girl. Dealing with Bose is sort of a pain. I'm planning to call em back later today and see where it gets me. Anyway, I was told the same. Apparently Bose had a bad vendor for the capacitors. They tend to leak. I still need to pull the sucker out and check em. I'm gonna try and fix it b4 I send it in. If they leak or blow you can usually see it. There will be an oily substance all around it. Sometimes causing a ring aroud it. In the old days, I'd hold a flashlight behind the circuit board and you'd see the oily ring. But you MUST replace it with the EXACT capacitor and watch polarity! Hopefully, if it doesn't reach 100 degrees today here in San Antone, I plan to work on it a bit. If by chance you know which capacitor or the rating, please post it.
robert
