Bosch CBV?
lostmenoggin
Car: 1989 Nissan 240sx ca18det swapped
anyone use this compressor bypass valve on their CA? im wondering if it will work well because that is a hell of a lot cheaper than a BOV...
http://jimwolftechnology.com/c...D=458
Logan76
Car: Junk
A bypass valve isnt a blow off valve, it will leak, Bypass valves dont have a stiff enough spring and it will not hold the pressure of boost.
driftin8ez
Car: 92 Coupe, Turbo Miata
Sorry but i disagree. I have that on my car and it works great! They come stock on VW and audi. Mine was off of a Audi TT. The vacuum line at the top is key to it's operation, that and as long as you recirculate the valve you will be fine. During vacuum it opens the valve allowing you to suck air directly into your intercooler piping from your intake pipe without having to go through the turbo so it gives you better throttle response off boost. When in boost the Vacuum line and the internal spring hold the valve tightly shut allowing you to hold boost just fine. Think about it.. Why would it leak under boost? You have equal pressure on both sides of the valve plus a little help from a spring. I say it's a great buy as long as you hook it up correctly. That would be manifold pressure for the vacuum line. One port on the valve hooked up to your hot pipe the other hooked up to your intake pipe after the MAF.
Logan76
Car: Junk
I just assumed he would'nt recirculate it. If this BPV is recirculated it will work just FINE...but if its not recirculated it wont work near as well for you...
driftin8ez
Oh ya.. If you don't recirc it your ****ed! Car wont even run right at all.
lostmenoggin
I never assumed that it was a BOV; i know the difference. i wanted to know if this was a reliable alternative to a BOV with a recirc fitting cuz it is way cheaper.
driftin8ez
Did you read my previous post. Go for it! What else can i say. It wont be loud but it will do the job quick handily.
lostmenoggin
yea, i did. my previous post was more for Logan. anyways, im going to order it friday! my swap is getting closer to being (temporarily) done
