bosch 044 intank install, s13 rb25det ( 56k might not be a good idea )
matafied
Car: 1989 240 rb25det 1992 240 rb25det
Well after reading and research I decided that a Bosch 044 in tank should be all I need for my power goals. So here are the steps I took along with my parts. I used -8 AN which is prob. overkill but better safe than sorry
Also do you think this will feed 500 rwhp??
* -8 12mm to 1.5 adapter* -8 bulkhead 90 deg* -8 bulkhead Nut* -8 to -8 female swivel* -8 strait swivel seal* -8 viton seal for bulkhead* Bosch 044 fuel pump* Bosch 044 fuel sock
Well I started by removing the factory fuel pump and removing the fuel level float, just to prevent damage. ( One Phillips head screw and with a soldier iron remove wire attached to float)
Then removed the factory pressure line to make room for the new pump. Also drilled the hole for the bulkhead to feed thru.
Smashed the opening of the pressure line and welded it shut. Also welded a new support for the fuel pump.
Fitted the pump on new assembly
Secured pump with hose clamp and spacer
Soldiered and crimped new ends for power cables, and reinstalled float assembly.
well thats about it
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
I don't think those zip ties will live long in the gas. Also why didn't u just run a bigger power and ground for it? Other than that very good job!.
matafied
Yellow4g63 wrote:I don't think those zip ties will live long in the gas. Also why didn't u just run a bigger power and ground for it? Other than that very good job!.
yea, i had those on their just to keep the sock from slidding to far up, i guess i should replace them with a small hose clamp.also another good point is the wire size i was also thinking that, and i am replacing them now.
WhatsADSM
Car: 1998 240sx
The pump is fine to 500whp... But I would also do the wiring as mentioned before.
I forget off the top of my head, but what is the size of the stock feed line? Because that also could be a limiting factor.
matafied
its all new -8AN braided but i was thinking that the return may not be big enoph and might cause high fuel pressure. Anyone know if the factory return line is going to work or will i need to go bigger??
gawdzilla
Car: none
factory return should be plenty for 500whp. the factory feed and return are good for around 600 whp i believe. a single walbro on 5/16" fuel lines (factory size) can break 500whp. nice install though.. should give you a good safety net for 500rwhp.
StricNyne
nice i wanted to see that for a while man 044 is awesome i got a can of beer in my fridge thats the same size
Carl H
044 in an s13 = easy044 in an s14 = worst 3hrs of your life.
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
will the walboro pump with stock feed and return and tomei 600cc injectors be capable of 500rwhp? cause my new turbo setup is capable of getting me to that hp goal but im worried about my fuel setup.
Carl H
i wouldnt fit a walboro pump to any 'performance' car.
RB_Seth
Car: 92 240sx RB25
91 240sx LT1
95 240sx 280k mile DD
that sure is purdy, i was wondering how hard it would be to fit one in the tank.... doesnt look too bad, just a real tight fit lol
matafied
worked out really well, dropped right in
Cjmartz2k
Car: Hunting for a '89 GTR now
Man, I just saw this write up after I put my twin walbro's down in the tank. I wish I would have done this instead.
