GraySilvia »
https://forums.nicoclub.com/graysilvia-u3605.html
Mon Jan 27, 2003 11:19 am
Hi ya'll, just browsing the board and saw this post....
Here's the deal with boring an SR; It's not easy
The SR20's have nikasil linings/sleeves that are only about .01 thick. FSM says service limit on these sleeves is .008 over and after that has to be recoated or sleeved. I've been toiling for months over what to do about forged pistons because you can just get 1mm over pistons, bore it, and drive away. Well, you CAN, but, it's not going to last. So, you have 3 choices.
1. Hone the block (must use a DIAMOND BIT on nikasil) and have custom pistons made for the new bore.
2. Bore the block and have the cylinders replated with nikasil, then have pistons made, so you can go 1 or 2 mm overbore
3. Put in ductile iron sleeves. Then make pistons and/or bore to your hearts content.
I'm doing option 1 because A) it's the cheapest and B) nikasil is far superior to iron cylinder walls. Nikasil is harder, more durable, and has less friction than iron cylinder walls do. This seems to be a gray area on this board, it's taken me a long time to figure out how to make pistons for my motor, and not many people realize that the SR has a nikasil coating. I hope this helps you guys.
