JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Tue Jan 14, 2003 8:19 am
Actually, Nissan recommends that when you bore, you only go .5mm over each time, twice maximum, for a total of 1mm. In other words, the first time your rebuild your engine, bore .5mm (from 89mm to 89.5mm) then the SECOND time you rebuild your engine (god forbid), you can go another .5mm, or up to 90mm. I asked my machinst about going directly from 89mm to 90mm when i had him bore my block and he said that taking out that much material at once could cause undue stress on the block. He didnt recommend it. So i have 89.5mm bore now and its just fine.
If you DO go to 90mm, the displacement would then be 2443cc, where my 89.5mm bore gets me a displacement of 2414cc. Stock, of course, is 2389cc.
