borg warner S256 on a SR.
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
http://www.timsturbos.com/S256.html
From what I see this turbo is very similar to a GT3076R but with a much broader MAP. What do you think it compares to. I am also considering the Holset HX35. http://www.timsturbos.com/products-2.html
I am strongly considering going top mount over the winter. I will be racing a 08 Z06, a 07 911 turbo, and a 89 930 slant nose with my 2871 bottom mount next month and then I'll be tearing my S13 down for paint and possibly a top mount setup for next year.
Any suggestions would be appreciated.
Kalypso
nzmoman was asking the same question...
there's a thread on the holset
zerothread?id=306724
BW k27.2 is also like the twin scroll gt30.
480sx
Car: 1996 Pearl White 240sx
A 256 will hit 550 hp and have pretty much the same spool up as a gt30r.
As a sidenote, Tim is a personal friend of mine. Let me know if you want a turbo from him i can get you a good price.
CSUPUEBLOTIM
Car: 1992 240sx Sr20det Coupe Silvia Front
Not to get off topic but whats your current turbo your running?
jr_ss
Car: 95' S14
kentuckyslider wrote:my 2871 bottom mount
Someone failed english.... Read my friend
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
well he does have TIMMAY as his avatar, so cut him some slack. lol
kentuckyslider
480sx, I know you are running a KA-T but what made you chose the s258 over the s256. I think the S256 will be better suited for the spool up capabilities of the SR20. What turbine housing outlet and downpipe configuration do you suggest?
480sx
I chose the s258 because i plan to run daily 400 hp with the ability to hit 600 if i chose. Also my bud had a killer deal on the s258 that i couldnt pass up.
Its all your goals man. The s256 will have better response, but its not by THAT much. If you plan on making between 350-550 hp the s256 is perfect. 400-600, thats s258.
As far as your turbine housing id go with something like a .63 or a .70. The SR likes to rev so you will be moving a lot of air and you dont want much smaller. 3 inch V-band is the way to go, and those housings are pretty common.
CSUPUEBLOTIM
LOL. I meant to ask how many psi he is running cause his torque to hp numbers are closer than most of the dyno sheets I have seen from a 2871r.
kentuckyslider
20psi with stock cams and intake.
CSUPUEBLOTIM
Dang. I hate altitude..its about 4,695 ft. above sea level here and I doubt my numbers would be that high at this altitude cause I was planning to use the gt2871r.
