Code: Select all
store.crescendoaudio.com/pwx-6-5-mid-range/
*Took out your links because they were copying funny when I clicked "Quote"BigTDogg (MA) wrote:My two cents:
Get 6.5" up front in OEM non-Bose metal brackets, get those Crecendo mid-woofers for the rear boxes, sell the 4" Fosgates or use them in another car. You want your front soundstage to be the strongest.
1 10" sub is plenty, but driving it with 140 questionable quality Watts is not. Get a dual voice coil sub, so you can run it at 2 ohms, then look at a different amp. Something like this:
You will be gravely disappointed with 160 WRMS on a sub channel.
Deaden the doors with some Dynamat or equivalent and some foam to reduce/eliminate rattles. Run new speaker wires to your 4 main channels, you can get 14 AWG or 16AWG wire pretty cheap, like here:
I meant to type Crescendo lol I was reading something that mentioned Cadence wiring, and I guess it got stuck in my head.XX7R wrote:I'm not talking about cadence. Crescendo mids and crescendo tweeters on a sundown audio amp or zapco amp will literally be the clearest, crispest sound you'll ever hear... Nobody knows about this stuff cause its not mainstream.. But they literally knock everything else out.. (JL, alpine, mtx, kenwood..)
In terms of the speaker, I chose that particular JBL because it seems to be built to run on the low end. Not enough punch to rattle/shake things, but enough to get the bass effect.BigTDogg (MA) wrote:If you like a lot of highs, then that's your personal preference. In general, it's preferable to have the full range (20-20K) info coming from in front of you, especially with no rear seat passengers. Just look at what direction your ears face![]()
I like more mids I guess lol I listen to 40% modern rock, 30% techno/dubstep/electronica/whateveryouwannacallit, 20% classic rock, 5% hip hop (Eminem/Outkast is about the extent of it lol) and 5% misc.
Typically the rear speakers are rear fill, running from 300Hz to about 5-6kHz. You should definitely high pass the rear 6.5" above 250-300Hz so they don't hit the grills and trim once installed. Ask me how I know![]()
Bahaha. That's good to knowDid the grill/trim muffle the sound like the speaker had a pillow over it?
RMS power isn't only suited to thump, but to protection of the driver/speaker. If you ever did want to crank it, you couldn't do so without risking damage to the sub.
Well, that doesn't help this topic .. lolZ31toZ32 wrote:i would put my cash towards a SZ exhaust.
It looks to me like the Bose enclosures depth maxes out around 1 3/4 inch.XX7R wrote:To tell if a speaker/subwoofer can play low you wanna look at the specs of it. Generally, the lower the Fs and Qts a speaker has the lower it will be able to play hertz wise depending on the subwoofer enclosure. Anything below 20 hz is where the human ear can't pick up the sound. Are you gonna build a box for the subwoofer or just buy one?
I can measure if they'll fit but I haven't actually put any in my zx yet.
I usually just run the wire through the rubber door grommets and into the cabin of the vehicle
Sometime soon I'm going to be doing a really nice sound quality build for my zx. I'll post a build on here
Way to pour salt in the wound, he's NA budaaaaayyyy!!!Z31toZ32 wrote:ha i know. i rarely jam tunes in my car, i guess i just have more fun listening to the turbos and playing with the gears and gas.
*Sniffles..no turbos..sniffles*BigTDogg (MA) wrote:Way to pour salt in the wound, he's NA budaaaaayyyy!!!Z31toZ32 wrote:ha i know. i rarely jam tunes in my car, i guess i just have more fun listening to the turbos and playing with the gears and gas.![]()
Running speaker wire through the doors, fish it through the OEM opening/boots. Not fun, but doable.
I wouldn't bother with 55W HID kit. Did you clean the inside of your lenses before installing? What color temp are the bulbs? A projector retrofit would serve you much better than higher wattage HIDs.kowboydmac wrote:I'm sure a TT 90 Amp Alt would be more than enough, but I am interested in things like an electric fan setup, so I'd rather have the power already on hand. May also get some more powerful HID's, as I can barely see anything at night until I turn my highs on.
