audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Thu Jul 05, 2007 2:28 am
Thunderstorms took out my internet so it was time for something to do. With the FG project being wrapped around a C10a for the moment, I went ahead and put the TC 12" sub to use in my home system. Instead of building a new enclosure I simply swapped it into the JBL enclosure I am currently using. The JBL home sub is a 12" design with 250w. When I pulled the JBL sub I was hoping to see an ohm rating on the magnet but no luck, quick test with a multimeter showed 5.6ohm, so, 6ohm.
I installed the TC in parallel @ 2ohms for the moment . I will be changing it to series @ 8 ohm sometime today as the poor JBL amp will probably eat itself at that level. I watched a couple movies with it and it was a far improvement over the JBL sub. Further testing at greater volume will happen after I change it to series. Here's a couple pix:
