syka24et wrote:thanks. But will that make the car harder to rev.
only if you increase the stroke. how high and fast an engine revs is determined mostly by how long a stroke it has. usually, the longer the stroke the shorter the rpm range and the slower it revs. the shorter the stroke, the longer the rpm range and the faster it revs.
And as far as my powerband goes I assume there will be more low end power from the added displacement but what about peak power.
as far as the KA goes, there's not much room for any increase in displacement. even boring it to it's limit won't net much. a longer stroke usually produces a stronger low end. a shorter stroke favors a better top end.
Basically I'm asking what are the pros and cons of bore and stroking
i can't think of any cons to increasing displacement. boosting is good, but boosting bigger cubes is better.![]()
-demetrius
