Boosts...but no more power?
bdrifta
Car: 1992 Nissan 240sx sr20det
I know i have read this on here before...but i can't for the life of me find it.
I have a redtop, all stock except exhaust.
When i boost my car doesn't get hardly any more power...it will drive fine way up to like 5k....but when i punch it...or even go like half throttle, it loses boost.
I have had an exhaust leak right before the turbo for a while now, but it still builds boost fine.
Any help would be greatly appreciated.
Tartan
Car: 89 240sx
It sounds like a boost leak to me check for leaking couplers, pipes, vaccuum lines, etc. Last time I had that problem I had a kink in my vaccuum line going to the wastegate actuator. Was this a growing problem or did it just happen one day?
bdrifta
I was driving hard last night...drifting...and on the way home it started...ill check lines and stuff.
Here's the weird thing...it wasn't noticable on the way to work this morning.
EDIT: I was just rereading my origional post...and i didn't quite explain it right. It does NOT lose boost, my greddy profec b spec 2 reads the normal 8...
bdrifta
so i pressure checked my ssytem upto 17psi, and there wasn't event a slow leak that i could find...
my exhaust leak got worse...
but it doesn't seem to be doing what it was, thanks anyway.
Valley
Car: 00 celica gt-s 89 240sx hatch
hmm... something bent? do a leakdown and/or compression test, that will tell you if you're loosing it from the motor as opposed to exhaust/intake systems.
