EVILS14 wrote:heres my problem. If im driving through town and try to boost it cuts out really bad for a second and if i keep accelerating it clears up and boosts fine and if im on the highway and try to boost from fifth it will cut out for a couple seconds then it will clear up but if i downshift to third or fourth it boosts fine... any suggestions?
why would you try to boost from fifth? Do you have a 6 speed?
If your car is a 5 speed try to avoid boosting in 5th gear, if not for mechanical stability but for fuel reliability. It is mostly a cruising gear, not intended for a lot of acceleration. You won't build a lot of good boost quickly in 5th anyway.
Do you have a boost controller that you can see for sure that it's not building boost properly? And if so, around what RPMs does it get out of vacuum (Say going from 2nd to 3rd gear for instance) and start building boost, and when does it peak?
Also, your problem is more than likely your fuel pump. You won't boost properly if you can't get enough fuel to balance out the compressed air. Put the 255 in & then let us know if you still have a problem.
