Boosting problem
clever240sx
Car: Nissan 240sx
Ok it drives just fine sometimes but once in a while it just all out looses boost and pushes straight air out through the bov. Whats the problem?
themadscientist
Explain that one again, not sure what you mean.
clever240sx
Car: Nissan 240sx
Ill be driving and it will boost just fine. And then outa the blue it will loose boost and it will just spray out air of the bov when i rev it up. And when it does this, the car will die. But if it doesnt i shut the car off and let it sit for a few mins and then it boosts just fine.
ISUJinX
Sticking wastegate or BOV? Or your boost controller isnt working properly. If its electrical, check the grounds first.
Carl H
better question what kind of bov do you have?ive found that the apexi valves tend to get sticky over time and have to be dissasembled and lubed with something hella viscous to work properly again.
clever240sx
Car: Nissan 240sx
Ive got a ****ty Greddy. Maybe thats the problem...where abouts do i lube it up at?
Chaos the Xile
Car: 1974 Datsun 260Z
is your bov recirc'd? I know that it being atmospheical isn't teh issue I was just wondering. Its prolly the boost controller.
themadscientist
Sounds like a stuck BOVPop it off and spray some WD40 on the BOV piston and pump it up and down in the bore. Slow at first and then quickly near the end. Remember nice guys finish last.
Carl H
themadscientist wrote:... and pump it up and down in the bore. Slow at first and then quickly near the end. Remember nice guys finish last.
sleazy!
