boosting 6psi now
red s13
Car: 240sx
I turned up the boost to 6psi and my car feels way quicker, but now when it gets to about 5k rpms it feels like its a little slow to get to 6k rpms.
crzycav86
Car: 93 Nissan 240SX KAT
Congrats.
What turbo are you using. And what engine management? You might be running decently rich from 5-6k rpm, and that may be slowing you down a bit.
Craving4Boost
Car: 91 240sx fastback
yeah wat are your AFR's? your air flow gets less at that rpm so you'll want to lean it out a bit
240DRFT
turned it up to 6...what were u boosting before??
red s13
Car: 240sx
I have a 57trim t3/t4e, walbro fuel pump, 370s injectors, 300zx maf, s-afc2, and a stock ignition system. I started boosting at 4psi, but thursday Im going to turn it up to 9psi. My lm-1 reads 11.8 while boosting, so do you guys think I need to lean it out a bit for higher rpms? I always thought your supposed to richin it up the higer you rev. Oh yah how much psi do you think I could run with 370cc injectors and my t3/t4?
Jookmasta
ur gap on ur plugs is the issue. what gap are u running at?
crzycav86
Is it really?
Mine are gapped at stock... but I didn't notice any misfire or hesitation on boost.
Mine slows down at 5-7k because it's at 10.5 a/f, which will be fixed when i get a new clutch.
red s13
Car: 240sx
I have ngk bkr6es-11 and there gaped at .28. So I don't think its the gap, but I did pull the plugs today and there a little black.
nissanfanatic
Car: 1992 Nissan 240sx SE
When I tried to run my car at 5psi on stock gap, I couldn't go past 1psi. Stronger coil is in order as well.
You need a wideband.
AN89HATCH
my plugs are at stock gap and im running 7.5 lbs and no probs
red s13
Car: 240sx
Im starting to think that the plugs are fouled out ill change them tomorrow. I really need help because Im suppose to race my friends mk3 supra, and that thing is fast and all he has is a upgraded ct26, 3''down pipe, intake, and exhaust, running 9psi, and that thing pulls. so after I get all the bugs out do you think I have a chance at beating him if I run 9psi?
crzycav86
Yes. His car is almost 1000 pounds heavier.
But don't race him UNTIL you've worked out the bugs. You don't wanna blow your motor, do ya?
red s13
Car: 240sx
Your right, but how much timing should I pull for 9 or 10psi? Right now Im at 17 degree btdc and running 6pounds of boost.
