WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Thu Jan 06, 2005 6:35 pm
As with any type of fuel managment. install the parts and get it on a dyno to make sure your not running lean. So with the HAcked MAF and FPR you can get on the dyno and check your AF's, it they are to low, crank the fuel pressure a few lbs and richen the mixture up. Either way I'd retard the base timing 2 degree's just to be safe. Well actually I wouldn't, but I have the MSD Knock meter also, along with the LM1 Wide band. I can't live without both of those. In a nut shell, yes, I'm saying stay with the hacked MAF and 370's.
WD
