WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Thu May 12, 2005 7:24 am
Straight T3 with a .48 AR, good for 12-15 psi with no lag problems. But not good for much more then that. So if you stay below 10 psi, get one of those.
The thing about turbo's is this, the compressor maps will only tell you 1/2 of the equation, flow and whatnot is great, but the exhaust side is very important, when it comes down to power production.
A typical T3 exhaust housing with a .48 AR is great for almost instant boost when matched correctly with a good compressor. But the .48 AR is to small to make big numbers without turning into a total heat pump. Now the .63 AR is almost perfect for the KA24. Plenty of flow and almost no lag. This is the exhaust housing that almost everyone ends up with, even if they started with a smallish T3 with a .48 AR.
The best turbo for the KA is definitly the T3/TO4E in 50 trim with a .63 AR exhaust housing. It has very little lag and will flow enough volume for 450WHP or so.
Search around, Like I said in your other post thread. The info is already here. You just need to read through a couple threads to find it.
The answer to your question is you need to worry about boost and flow.
