Chris28 wrote:If you are running anything more than say 6 psi, I would highly recommend a blow off valve unless you feel like replacing your turbo frequently.
very debatable.
I beat the s*** out of my car the week or two I had no bov installed, at 11psi, had to replace a turbo to manifold gasket and inspected the turbo, it has the same amount of play it had prior(none lol). I think around a bar I would start to be concerned with the ill effects of no bov, I reinstalled mine cause the flutter was screwing with my n60 giving me a worse stumble than suck through and vta bov was Any who BB turbos are less prone to a failure related to no bov.
op unplug the bov and see if your reading goes up
