rico05 »
https://forums.nicoclub.com/rico05-u8176.html
Tue Mar 04, 2008 4:36 am
A factory T25, with factory exhast will do that. It's just out of its efficency range at 7000RPMs. Factor in the restrictive stock intake and exhaust hardware, and there you go. Run 3" off the turbo back, and a hard intake pipe and you will hold boost better. I hold 1bar from about 3200RPM until I shift around 7200RPM. I have HKS SMF filter, KA MAF, hard intake pipe, T25G .80a/r and 3" off the turbo with hard intercooler pipes and an ARC intercooler. Hope that helps.
EDIT: I assume you were trying to refrence the factory boost solenoid? I have never run one as mine is a swap, but I could see the ECU limiting boost higher in the RPM range to reduce boost (and therefore thrust loads on the pistons and rods) to maintain longevity.
