airman86 »
https://forums.nicoclub.com/airman86-u126597.html
Mon Mar 09, 2009 6:50 am
i wouldn't go over 350hp on stock internals, you'll probably want to rebuild it anyways (new rod and main bearings as well as rings). while it's apart you might as well spend the $300 it takes for a set of eagle rods which are good for ~500 horsies or so.
you'll need a stage 3 clutch for sure if you're going over 300lbs of torque.
