Boost!!! :)
BoostMyRide
Car: 1989 Nissan 240SX
ok im buying an SR20 and wanting to know what turbo upgrade i should buy on a fairly limited budget, looking for about 350WHP, so the turbo has to support it any suggestions?
480sx
Car: 1996 Pearl White 240sx
Go to the SR forums and do a lot of reading, you can answer all your questions there.
350 hp isnt cheap at all. You might want to start with a stock SR and save your cash. My stock s13 SR with a FMIC put down a 8.5 in the 8th mile which is about a 13.2 in the quarter. Thats fast as balls for a stock engine btw.. 350 is just a number, your looking for a fast, fun car, and a stock sr is reasonably economical and a good way to get that.
adrianfromthecastle
Car: 1992 Nissan 240sx
z32 mafs: 50-100 on classifieds, you might get lucky at the junkyard550 injectors: ~400gt2871r: ~1200ebay fmic:~200safc + wideband: ~400ish (or get a real ecu tune or something for more)boost contoller: 200+ depending on brand name
BoostMyRide
wow kinda expensive, im using the car for mostly a time attack situation gettin through windy roads FAST! i know most will be suspension but i want enough power in the motor
adrianfromthecastle
yeah.. spend more time/money on your suspension (i.e. coilovers, bushings, arms, etc). imo, 230whp is fun enough for the streets.
