redtop91 »
https://forums.nicoclub.com/redtop91-u46681.html
Fri Dec 08, 2006 7:07 pm
Under 350 WHP a chipped ECU will do fine. I am at 7 PSI with stock injectors but I have a JDM SR ECU that's been rechipped with a Mine's Engine Management program. The only thing most boosted 240's will need is an upgrade MAF (Z32), high volume fuel pump, injectors and an ECU reflash. Although making any sound advice on this issue would require knowing what car you have and what engine it is . If its an SR20 all you need for 350 WHP is the .86 A/R GT2871R turbo, 740cc's (overkill maybe but it you ever decide to up the boost later on down the line you'll be happy plus you'll have a good safety zone and won't max out the injectors) MAF and FMIC. Nothing else is really necessary.
