boost
blacknissan92
Car: 92 nissan 240sx turbocharged
how much psi can you push in a stock ka24de 16 valve
Florida240sx
Please search. Been covered many times. It all depends on your set-up, and tuning.
Suicide.Veteran
Car: 93 Nissan 240sx
besides its easier to say it can take aound 350 hp on a good build and safe tune. And 350 can be anywhere from 15-20 psi depending on turbo and build.
nissanfanatic
Car: 1992 Nissan 240sx SE
I push 22psi daily, but I've ran up to 31psi. 31psi was an accident, but it was a full 4th gear pull. I've ran 25psi sustained on the street for a night..
I broke 350whp at 14psi.. 414whp was made at 24psi.
Chezedik
Car: 1991 Nissan 240sx
How long have you been running that, and are you still at stock compression?
nissanfanatic
About a month before I left for the Navy and now since I registered my car on leave circa November 1st.
I'm completely stock except for a cometic headgasket.
C-Kwik
You should also describe what turbo you are using. It can make a big difference in how well the engine can make power and handle the boost pressure applied.
Chezedik
That may be the shortest C-kwik post I have ever seen.
Jookmasta
ur right it is. lol. cory is running the tried and tru 50 trim t04e.............more specs are found in the link in his sig.........
Chezedik
Cory, what are you using for tuning again? Is it BTM and SAFC or something else?
