boost
blacknissan92
Car: 92 nissan 240sx turbocharged
how much psi can you run with a stock ka24de motor
180fan
Car: 89 fastback
depends on the condition of the ka you're starting off with. mileage, how well it was maintained, etc all play a role in this.
blacknissan92
120tho well mantian
180fan
Car: 89 fastback
take it to a tuner to dial in the right amount of boost. details on your setup. type of ic, injector flow, turbo model and trim, etc
rogoman
Car: 1991 240SX FB
2012 Altima 2.5 S
blacknissan92 wrote:how much psi can you run with a stock ka24de motor
7 to 8 psi is a safe limit. When going beyond 8 psi, the OEM pistons start taking a beating; the top ring lands tend to break and touches of detonation burn holes in piston tops.
