Boost
Kenrik
Car: Nissan 240SX Coupe
Infiniti G35 Coupe
Nissan Versa Hatch
Ok so I just bought a MBC..
I got the Joe P XZ-s MBC which can raise the boost 7psi max (so even if it spikes the max it can hit is 15psi) and from what I understand it's pretty good about not spikeing.
Anyway do I need to do anything if I'm running say 12PSI? I don't need to mess with SAFC settings, getting a FMU or anything like that right?
I have a Walbro 255lph FP, FMIC, and HKS SSQbov.
Morph
Car: 91 Sr Powered Coupe
I think you should be ok, you are just gonna nearly max out your injectors.
Kenrik
Infiniti G35 Coupe
Nissan Versa Hatch
Morph wrote:I think you should be ok, you are just gonna nearly max out your injectors.
@ 12psi>???
I know someone who had a SR with a T28 hybrid that Dynoed @ 286whp @ 18psi on stock injectors (he had a FMU but still...) I know it's crazy but he drove around like that for over a year and it did not blow... he just upgraded his injectors and turbo now he's @ something like 350whp.
sr20detmaybe
Car: 95 240sx
yeh 12-14 psi on stock injectors with the walbro 255, the FMU would up the fuel pressure i think, havent messed with them so u may be able to get away with more boost with one of those, IDK
