Boost Spike
Nismo-S14
Car: 1995 Nissan 240sx SE S14 sr20det,1991 Nissan 240sx Coupe
hello everyone! well i have a 95 240 with an S14 sr, right now im running a PE1820 turbo, with PE wastgate. i have the wastegate line running to my hot pipe i had the boost pressure set at 10psi now when i hit second gear to fifth from 5000 rpm to red line im hitting 18psi i checked intercooler pipes any line i can think of nothing so anything helps thanks :biggrin: ! sorry for the improper grammer i typing this in a hurry!!!!
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
What size spring is on the wastegate?
Sugar
Car: S13 w/ Sr
If you have a screw on wastegate flange make sure it's sealed for sure. Having a decent leak there will play with the pressures quiet a bit. My friends car spiked up to about 20psi because of it.
Nismo-S14
it is a screw on wastegate flange i checked it. There are no leaks but when i try to tighten it a little more, the pressure went down it surges to about 1 bar. so i think I'm getting somewhere?
PyR0NiAk
It would seem so..
Sugar
Car: S13 w/ Sr
Get it where you want it and have someone weld it up. Screw on flanges are a joke.
