GraySilvia wrote:Ummm, that's how MBC's work. That's why some people choose Electronic boost controllers, because MBC's do that, call 'boost spike' for obvious reasons. It's completely normal.
Hes talking about the opposite. A boost spike is when you set it for x amount of boost, but the boost controller doesn't let enough pressure reach the wastegate and the boost continues to rise past the level you just set.
He is talking about setting the boost for 13 psi, but when he gets to high RPM's, it starts falling off to 11 psi, which is common.
Run an SR with the wastegate unhooked. It will spike to ~20, then fall off to like 12 or 13 at the top end.
T25's are just too ridiculously small.
