boost question
implict
Ive got the mines ecu... and was woundering how much boost im gettn from it.
They dunno the specs but i found this so far.
BOOST: 0.9kg/cm2
How much is that?
Tai Mai Shu
boost is measured in Bar, Vacuum is mesured in KG/cm2
implict
well thats what i got from this site...
implict
you guys dont think that the mines ecu would mess with the boost would you???
SpeedRacer1
Car: 1990 240SX, G35
Im not sure if the ECU could directly change the boost. Boost is changed by fluctuations in the vacuum hoses or the wastegate. The ECU has no control over either of those when you do an SR swap .
BTW, 0.9kg/cm²= 12.8 PSI
implict
Well if it doesnt change the boost... then why is this guy sayn it does?
http://cgi.ebay.com/ebaymotors...33597
so am i runnin at 12.8??? or the reg 7.....
just wanna know.
implict
i dont have a boost conroller or boost gauge...
Tai Mai Shu
boost gauge is 30 bucks, be a baller and buy one that way you can be sure. Without my greddy profec B connected my wategate wasnt opening till about 11psi, but it didnt matter i run 1 bar daily. Of couse I dont use it all, most the time.
SpeedRacer1
They seller is not saying it will increase the boost to 13 psi, he is saying the previous owner used it while he also had boost set at 13psi using some other device.
The only things that ECU features are: No speed limiter and no boost cut, and the ECU is "tuned" to respond to the basic bolt ons better (probably with a remapped fuel curve).
implict
so u think im still at 7 psi???
implict
im just asking all these question cause the only thing i have done to car is that ecu..... and yesterday i was out at night on the interstate just crusing around and a integy came next to me and reved... so he droped his in 3rd and so did i..... i pulled really hard and killed him so bad... so he told me to get off the next exit and i did.... and asked me what i have done.. told him what i had and he didnt belive me so i poped the hood... his eyes got real big.. i gues he knew what he was lookn at.... but he was a gsr spraying a 75 shot...he told me he sprayed... he caught up to me though... i guess thats when he hit it... he was at my back bumper.
Long story short... if im at 7psi still... then dayymm.... im one happy mofo
I have the video, and will try to upload it somehow.
Thanks jeff.
SpeedRacer1
Yes. The ECU probably has a tuned fuel curve that has been crafted to make more efficient power if you run 13 psi on the stock turbo. Thats probably what it means.
BuudWeizErr
yes
implict
so im still at 7??? right?
implict
Bud on ur site u said
"The other problem is during high RPM's, the rocker arms can come lose, and if that happens, all hell can break lose under that valve cover."
Thats only when you rev in high rpms right???? or is it at high rpms period?
B.L
0.9kg/cm2 = 0,9bar =13psi
SpeedRacer1
To be more accurate:0.9 Kg/cm² = 0.8825985 bar = 12.80101 PSI
Bar and kg/cm² are not the same.
B.L
i know but the difference is so small...
implict
so the ecu didnt change how much boost im pushn?
( just wanna make sure im at 7 still )
SWIFT_DRIFT
BUY A BOOST GAUGE AND FIND OUT! SPEEDRACER ALREADY TOLD YOU THE ECU WILL NOT CHANGE THE BOOST.
implict
damn dont gotta get all gay about it.
SpeedRacer1
Well you did just ask if you were at 7 psi 4 or 5 times. Everytime the response was yes, there was no "actually your running *PSI" so its understandable that Swift might get a little upset.
SWIFT_DRIFT
well people are telling you answers and you keep asking over and over AM I STILL AT 7>?!?! OMFG OMFOGMOMFOMG AM I STILL AT 7?
Gregariousgreg
Car: Cars, snowboarding, psychology
If you're running at 13 psi instead of 7 then congradulations, you have a magical ECU :P :)
bob marley
Correct me if I'm wrong (still learning) but I don't think an ECU can raise the boost. All the ecu does is send a signal (or in this case it doesn't) which limits the amount of psi/bar the turbo puts out. This is why you need a boost controller.
Right?
Is this mines eco worth it? Anyone else have it on their car and care to share some info?
Johann
Gregariousgreg
I think the biggest reason most people like to get ECUs for 240's is it takes out the rev limiter and the speed limiter so you don't top out right at 115 mph like you do if you have the stock ECU.
SpeedRacer1
You stop at 125-130 on the stock SR ECU ;)
BuudWeizErr
bob marley wrote:Correct me if I'm wrong (still learning) but I don't think an ECU can raise the boost. All the ecu does is send a signal (or in this case it doesn't) which limits the amount of psi/bar the turbo puts out. This is why you need a boost controller.
Ugh, no. The ECU doesn't control boost at all. In fact, I doubt that the ECU even knows how much boost is being thrown at the engine. The ONLY thing the SR ECU does is feed fuel to match the signal coming from the AFM, and then spark.. A boost controller doesn't hook up to the ECU at all (unless it's some gay piggyback crap like the AFC).
If the ECU could control boost, in any way, it would require for an electrical wastegate. And I don't even think those exist. We have mechanical wastegates. They require a certain pressure to open. Which, in this case, is 0.5BAR.
