:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Sun Mar 07, 2004 2:14 pm
Check the adj on the wastegate actuator...I'd bet it's a little loose, allowing the WG to open prematurely, hurting spool.
Tighten it some, to preload the actuator, and try again...let us know what happens.
Also, where is the WG signal from? If it's the compressor outlet, then the intercooler could be providing a 2psi pressure drop, so the mani only sees 5psi, but the turbo outlet shows 7 like it should. Try switching the WG line to the intake mani if it's on the compressor outlet...
Later - Brian
