Boost problems
Nismo20
Car: 1989 NIssna 240sx with S14 Blacktop SR20DET
I am having problems holding a solid boost at 14 psi. I am still running stock turbo. When i turn the boost on high it is set to run at 14psi. It will not hold a solid 14 psi, it fluckuates between 10 and 14psi. I performed a boost leak test on it and i had no leaks. Does anybody know what it might be and how i can fix it.
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Is it the stock wastegate actuator/spring?
Nismo20
yeh it is the stock actuator.
redtop91
The spring is extremely stiff on the stock actuator. I can't get mine to boost past 10 PSI. An actuator upgrade might be in order. What kind of boost control are you using?
Edit: Noticed it was the S14 SR. Not familiar intimately with the actuator on there but I assume the problem will be the same/similar.
S13FASTBACKSR
Car: '92 Fastback SR powered
im guessing that either your turbo or actuator has just got too many days behind it and can no longer hold that amount of boost..unless you are running a crappy MBC that could also be the problem
Nismo20
its an electronic boost control
redtop91
Is it freshly installed?
S13FASTBACKSR
alright well in this case what i would do is look into the actuator being bad or the turbo..usually its the turbo that gets old enough to where it cant hold that amount of boost..14psi on a stock turbo is maxing it out so trying to hold a steady 14psi on a stock turbo that has seen its days is asking a lot
Nismo20
well the motor only has 50 thousand miles on it, so i wouldnt think that the turbo would be bad already
S13FASTBACKSR
its not exactly the mileage thats on it but how that mileage was put on it..nice and easy..or driven hard/ beat the hell out of
Nismo20
I drive it nice and easy. Eveybody tells me that i drive like a grandma cause i always baby it.
redtop91
You might want to take off the turbo and check side to side play. That or an actuator upgrade or verify you setup your boost controller properly.
S13FASTBACKSR
Nismo20 wrote:I drive it nice and easy. Eveybody tells me that i drive like a grandma cause i always baby it.
Ok but you didnt put all 50,000 miles on it did you? Do you know the person who owned it before you or know how they treated it?
Nismo20
no i didnt put the 50,000 miles on it, it i got the motor in a front clip from japan, and had a shop in tampa florida build the car.
S13FASTBACKSR
ya i figured that you didnt put all 50k on it thats what i mean..you dont know who had it before you or how that person treated it either..very possible the turbo isnt making boost and its very possible its not..what you should do is hook an air compressor up to your actuator and apply pressure to it and see if its opening to eliminate whether or not its the actuator.
LordOfTheMiasma
Car: s-13 hicas sr20det 240sx
not trying to be of topic.. but u baby it and drive like a grandma on 14 psi lol... as said before its probly the turbo.
Nismo20
No i dont drive around on 14psi, i drive around on 7psi. i only turn it up to 14psi when i am racing it, which is hardly ever
