Wretched »
https://forums.nicoclub.com/wretched-u141421.html
Sun Aug 23, 2009 3:14 pm
Sounds like a leaking bov. Try tightening down the adjuster all the way. Disconnect the vacuum line to it. Wrap the bov in Saran (sp) wrap real tight, use a rubber band to make sure...run it down the road...check it when you get back. If it exploded, the bov is probably leaking. Kind of ghetto, but it works.
