Boost Problem
ROZE
Car: 1990 240SX w/SR20DET Redtop
I am running a stock T25 on a Redtop SR20DET. I use a Apex'i AVC-R to control my boost, I had 2 settings:a) 0.60 b)1.05
Everything had been working fine until recently when all get now is about 0.03. I checked the vaccum lines and all my pipeing and everything looks good to me. If anyone has suggestions please let me know. Thanks
Nismo_Freak
Car: 89 Nissan 240SX
Bypass the solenoid, and run the lines straight to the wastegate from the intake manifold. If you build boost then you have a bad solenoid. If not, then you have a turbocharger problem.
Apexi has had issues with their solenoids.
ROZE
You mean take the vacuum from the intake manifold and run it into the wastegate acuator on the turbo?
Nismo_Freak
ROZE wrote:You mean take the vacuum from the intake manifold and run it into the wastegate acuator on the turbo?
Yes.
drifting240
Car: computers, basketball
what solenoid are we suppose to bypass???
ROZE
Hey Thanks for the info. I found out what it was, it was the pressure sensor for the boost controller. I blew into it and it didnt track anything, got a new one and its boosting again. Thanks
