turboex »
https://forums.nicoclub.com/turboex-u1618.html
Fri Jul 11, 2003 5:53 am
Ok i have a stock sr20det redtop and only mods realy are 3inch exhaust turbo back, and intercooler. Now when i boost 7psi the car holds 7 psi, but i tried 14psi and im having problems. The car will boost to 14psi say in third gear and then after a sec or two the boost drops and settles at about 9-10psi. I checked the piping for leaks (via presure tester) and its fine, i check the exhaust for leaks and nothing there. Now for my boost controller im using a 2 year old turboxs unit, would this be the problem or would it be that the stock wastegate actuator just cant hold that much. thanks for the help
