encasemyheart wrote:I understand that, but imagine the stress put on the pistons N/A even, I assume controlled combustion is pretty harsh, I've heard that exhaust gasses travel at almost mach 1 out of the head, so I assume another 30psi isn't going to do much assuming it is controlled combustion and not detonation.
Could you run high boost levels (22 or so psi) on stock internals with 110 octane race gas and alcohol injection and a REALLY good intercooler sprayed with nitrous? (N-tercooler setup)
WD says you can do 15psi on stock internals with good tuning, so I assume with some of the above mentioned additions 22 is just a few steps away.
Wouldn't it be sweet to make 400+whp on stock internals...
You are right to an extent, but running that much boost is impossible. Yes, the better you tune, the more boost you can run, but you get to a point that it is impossible to tune better.
Like Ace said, oil starvation would be one problem. Another problem is, if 30psi of air is coming in, that doesn't equate to 30psi extra exhaust gasses coming out.
For simplicity, lets say a NA car runs 0 psi (reality is it has vacuum, but that should prove my point I'm about to make even more so). With 0 lbs of air being pushed into the engine, the fuel mixture ignites, and causes X big of an explosion. Now you run 5psi. You now have 5 times the air coming in. 5 times the air means 5 times the size of explosion in the combustion chamber. Since gasses expand when they get hot, an explosion that started as 5 times the original, ends up as 5 times the original. So at 30psi, you are pushing exhaust out of the car 30 TIMES faster than at 0 psi. So if exhaust traveled out of the car at a theoretical mach 1 at 0 psi, then it would leave at mach 30 at 30psi. Ofcourse, this is all completely theoretical and approximate.
The other problems you run into, is that it gets exponentially harder to tune, not linear. If tuning a car to 14psi is twice as hard as tuning to 7psi, then tuning to 21 psi is 8x harder.
At those pressures, also, you are putting 30 times or more stress on all the parts. For instance, connecting rods. Lets say a piston normally puts 1000 lbs of force on the end of a connecting rod at TDC. Well, at 30psi, that is 30000 lbs of force.
So you should get the picture by now....lots of things come into play.
