SpeedRacer1 wrote:If you used a manual boost controller you could set the boost to 12 psi and it would have no effect on the ECU. The stock solenoid is the only way the ECU knows what the boost pressure is at, if you dont have it the ECU just pretends it is at the stock setting. If your ECU is in limp mode, run the ECU for error codes and fix the errors, this is the only way to reset the ECU.
So you are saying the ECU thinks you are running 11psi without the stock solenoid? I am not running the stock solenoid, and running about 7-8psi...Could this explain why I am running rich?
Modified by whiplash willy at 8:42 AM 4/3/2007
