boost on ca18det
turbocorolla
Car: cars
hi guys,is a stock bottomend capable of supporting max 23-25 psi?ofcourse with propper fuel and timing control(microtech engine management)turbo will be a t3/t4 and 720cc injectorsplease your opinion on this!!!
Movingviolation240
Car: '95 Nissan 240SX 400hp SR20DET -SOLD
'93 Lexus SC300 w/ SP66 turbo kit
it could, but you'd have to be damn carefull. The stock headbolts would need to be 'over torqued' and you would need a lower compression head gasket.
What kinda HP are you looking to make with that? Over 300rwhp the CA is pretty weak as far as the pistons and bearings go so you'd want to look into those pretty soon. But it would do it once or twice if you were just tryin to get some good dyno numbers. I just wouldn't try it more than a couple times.
Paul
turbocorolla
Car: cars
ive read somewhere that the stock bottomend is capable of 350hp!is it thrue?my goal is to reach like 320/350 hp and a low 12's 1/4 mileor even a 11.9.................as you can see my signin name, the ca18det is in my ke-35 corolla(not running yet)and the car weights like 1900 pounds so is it gone do a low 12's?
Nismo1182
Car: Z06
I dont see a reason why it shouldnt. A light car and a good set of tires.
