Boost leak tester
Including VA, WV, MD, DE, DC, NJ, PA, CT, RI, NY, MA, NH, VT, and ME
Kelbizzle
Car: 91 240SX SR20DET
Anyone in or around the Baltimore, Md area have a boost leak tester or a smoke tester?
Razi
Car: Moo
You could try building your own for cheap with stuff from Home Depot and Autozone.
Find a PVC cap about the size of your intake pipe, drill then put on a brass fitting, connect a hose to that, then connect a small bicycle or car tire valve to it and pump it up with a bicycle pump.
That's what I did with mine.
I made that, works great. Later I took off the tee and the gauge because they aren't really needed.
Just squirt some soapy water on suspect areas, and also listen for the leaks very carefully.
Return to “Northeast Region”
