boro drift »
https://forums.nicoclub.com/boro-drift-u103655.html
Thu Sep 17, 2009 2:34 pm
You need a air hose fitting to screw into your block off plate, so you can plug your air hose into it. REMEMBER, to regulate it to 7psi, plugging a 100psi line into your motor would be bad.
When ever I do a boost leak test, I remove the bumper and spray soapy water all over everything. If you see bubbles, you got a leak.
