jms19delta »
https://forums.nicoclub.com/jms19delta-u136592.html
Thu Jul 23, 2009 4:04 pm
the maf would pretty much be right where I had it hooked up. What recirc valve? My bov vents to the atmosphere. I have tried putting the tester on the turbo (like above), I tried putting it on the ic pipe right off the turbo and I have tried putting on the ic pipe by the throttle body. I can hear air flowing through the ic pipes when I use my stethoscope. But I can never hear a leak anywhere. I am ready to rule out a boost leak. I have to be losing vacuum from somewhere. I have tried uping the idle with the screw on the manifold and no matter how much I turn it in either direction the idle does not change (unless I close it all the way then it dies). I unplugged the aac valve and nothing changed, unplugged the tps and nothing happened. The car revs fine, just doesnt do well under load. Could this be related to running so rich? If so, why would it all of a sudden start acting up?
