lrb_2000 wrote:the wastegate isn't going to open...becaues the engine isn't running, your intake and exhaust valves aren't open at the same time... it's just going to check for leaks in you ic piping, and vacuum hoses, depends if you open the throttle body or not...if you're going to be running 10psi, then test at 10psi...check the write-up, I could be wrong...
The wastegate will see the pressure in the IC piping if the signal is sourced within any portion that is being pressurized. From the photo, it looks like he is getting the signal from the compressor nozzle, so it will see bees as he is including the turbo in the test. The wastegate will start to open when it gets close to the set boost level, unless there is an electronic boost controller set-up.
