Retro-Cow »
https://forums.nicoclub.com/retro-cow-u209950.html
Thu Dec 13, 2012 12:07 am
Hello all,
So I've been lurking on these boards for quite a while just reading the articles and posts which are extremely helpful but now I'm completely stumped.
I fairly recently purchased a 93 Twin Turbo, things were alright at first and I fixed most of the problems that came with it.
However, relatively recently (as I've learned a bit more about the vehicle) I've noticed some problems.
The problems I am having are:
-Low Boost
-Erratic Idle (complete with engine shaking)
Obviously all signs point to a boost leak. So I purchased a boost leak tester with a gauge and have been trying to test for the leaks.
The thing is, the gauge on the tester doesn't even move when I pump air into the system.
When the air goes in it feels like it's venting immediately somewhere around the passenger side headlight area but I could just be hearing air going into the system.
Odd thing is some air is for sure being held in the system because if I manually open my BOVs, air vents out.
Furthermore, I was still able to hear a small leak in my PCV hose which I fixed so I guess air has to be held in the system.
I know for sure that the gauge on the tester works, I'm just wondering why it doesn't move when I pump air into it.
Thanks for any help.
