dre240 wrote:if i go fast on the gas it gets rough. if i go easy ,the car feels some what normal. i can go to redline.
It could be other things but good chance its a leak, one of the most common things I see in peoples cars. you have to pressurize your system with a boost leak tester and you can very easily find youre problem, heres a link to it:
zerothread?id=113785
If you cant access your turbo compressor inlet to easily since its a bottom mount, you can take off your filter and hook it up to the mafs and pressurise from there, just make sure if you do it this way, you block all nipples/hoses on your intake pipe. like catch tank and other crap that goes on the stock intake pipe or you will but pressure in the valve cover and other and whatnot.
