Boost leak, but how?
S13 King
Car: cars, performance, girls
Well I haven’t driven my car in about 2 months; however I’ve started up every now and then. Well the other day I started it up and it stuttered, on my boost gauge it read about 15vac. So somewhere I have a boost leak. This is odd thought cause when I parked the car it pulled at 20vac as it should. I’ll start going through things once I get the clutch back in it this coming week.Only thing I’ve done to the car was put on a power steering belt which got eaten up. I think that the power steering pump is bolted on with a KA bracket. It sits a slight hair uneven with the crank pulley.
also what is the correct power steering belt size for the SR20? I have a 94 blk top.
Silvia007
Car: 93 Nissan 240SX SE Fastback
If it reads 15 vac instead of the usual 20, you don't have a boost leak, you have a vac leak, I'd check all the vac lines to see if anyones cracked or hardend.
S13 King
yea sorry I ment vac leak. I'm trying to think of some hoes that it could be. I'm going to use the chart from sillbeer.com and see what I come up with.
GripR
Car: 92 miata
sorry to bring up this old thread back from the dead but, i'm experiancing boost leak. whenever i floor it, the car sounds okay but the thing is it doesn't have that kick to it. my car just speeds up but without the feel of the turbo. i went to sillbeer.com checked my vac lines, they're all good. anything else i should look for?
virus77
Car: 95 S14, 71 240z, 97 e320
That should help you out.
zerothread?id=113785
GripR
Car: 92 miata
thanks virus
