check this first, and if not, then maybe you have either a wrong wastegate spring, or a faulty one....hysteria wrote:umm what is your setup? do you have a mbc or any kind of bc? do you know what your wastegate spring is set at?
anyway a lot of mbc's i've found don't go lower than 10 psi.
i think it's obvious you don't have a ebc.
if you're running with no controller of any sort i guess you'll have to buy a different wastegate spring. check to make sure the vacuum passages to the wastegate are all in good shape, and that there are no vacuum leaks. this could very well be the problem ( the wastegate is just not opening).
hysteria wrote:i think it's obvious you don't have a ebc.
IanS13 wrote:well today i installed my cold pipe after trying to get the greddy cold pipe to work. nopi jerking me around with the damn cuplers so i can't use my greddy yet. well after taking it for a test drive my i hit 11.4psi what's up with that before it was only hitting 8psi i guess i had a boost leak well, now that i don't have a boost leak i need to figure out how to set my boost back to 8psi
*this is what my setting looks like on the greddy profec B spec2*Lo 17% Gain 10, set Gain 5Hi 15% Gain 15 Set Gain 90
