Boost jets???
demonyoka420
Car: 1991 Nissan 300zx TT, 1989 Ford Bronco, 1991 & 92 240 sx's
Havin a problem with my z going into safety boost and only boosting 7 when it should be around 14 cause of the jim wolf chip and boost jets i put inBut when i disconnect the vacuum lines for the boost jets it boosts 14-15 and is noticably faster. Can someone tell me if 1... if this is bad for the car? and 2... Why it would do this and what i can do to correct the problem without just dissconnecting these lines that are right under the main lines running into the throttle boddies.
Thanks...
SilverTwin
Car: '91 300ZX TT
The car is defaulting to 7 psi as safety boost, there is something throwing a fault code to the ecu resulting in the safety boost. The most common problem is code 34 which is the detonation sensor. This can be caused by a bad sensor or corroded harness, improper plugs/gapping or incorrect base timing.
To narrow your problem down you need to run your ecu codes to determine the cause of the safety boost. Here's a good 'how to' for obtaining the ecu fault codes:
http://www.ttzd.com/tech/diagnostictech.html
Pulling the vaccuum hoses will result in a boost/vaccuum leak and inconsistant boost levels. Overboosting will result in a toasted motor. Find the cause of the safety boost and correct it.
Tim
