Boost issues
wrgibson
Car: RB Hatch
I've got an RB20 swapped hatch with front mount and exhaust manifold...otherwise, stock.
If I slowly roll into boost, my boost gauge rises up to around 11 psi then gradually lowers back to around 9 psi where it sits until I lift. If I just romp on the gas the gauge rises up to around 9 psi then settles at 7 until I lift.
I'm on the stock turbo and wastegate. Any ideas of what I should check for? I'm not too sure if this could be caused by a boost/vac leak, but I'll check for them anyway.
Thanks for the help!
Cjmartz2k
Car: Hunting for a '89 GTR now
Check for the boost leak. Listen for a vacuum leak. What's the vacuum at idle? Could also be a leaky/busted actuator.
USMCgetsome
Car: OWN S13.5 RB25DET/2003 G35
i thought that was supposed to happen due to the boost solenoid on the bottom of the intake manifold!
datsunmotorsports
Car: 74 260Z , 71 240Z , 71 510 wagon , 68 Fairlady 2000, 82 Diesel Maxima
Seen that happen on engines with bad cylinders, or lack of fuel.
Check for vacuum problems first.
