boost issue
hpmachine
Car: '05 EVO8 + '95 240sx
I just punched every person I've ever seen. Yo does anyone know if running my mbc off the nipple on th turbo would cause problems with boost? Ever since I switched my mbc tubing from the intercooler piping to the turbo, it seems like it will only build around 10psi no matter how much I turn it up. I'm an idiot thank you.
drmerdp
Thats what the nipple on the turbo is meant for. Make sure you don't have your connections backwards.
The boost source goes to the bottom of the MBC.
hpmachine
Yeah I've got it right. I read somewhere that air turbulence caused by the compressor blades can cause inaccurate boost readings. Could this be the case?
hpmachine
bump for this question
