your problem stems from the physical limitations of your turbo. want to go higher? you will have to upgrade your turbo. above 12psi the t25 starts to loose efficency.climaxsr20 wrote:i heard that t25 will go 14 psi but will drop down to 10 or 12 psi when your motor is at high rpm. might be because of the small turbine. sorry to say but your best bet is to leave it at 12 to be consistant.
It's an SR specific question and it belongs in the SR forum.MeanGreenS13 wrote:man i put this in GENERAL so that everyone would see it.. no offence to you admins, but sometimes, ASK before you move things please, now i bet no one else answers.
Evidently not, you are still a noobie chief.MeanGreenS13 wrote:i just think ive been here long enough to know where things go, and if i dont put it there... its for a reason... i needed immediate answers, not an answer in 3 days
You have an attitude problem.MeanGreenS13 wrote:boostin issue could apply to RB, KA, CA, VG, or SR... i did not specify, because i know there are people from EVERY corner of boosted nissans that could possibly give me an answer. and thats my answer to you, as for the boost problem, i got it fixed by putting a stock gate back on and turning up the MBC to 14. it holds there strong and steady most of the way. and drops off to 12 at about 7500rpm but thats it. my previous problem was it would spike at 15 to 17psi around 3500rpm and be at 8-10psi by 4000rpm. please lock this thread and thanks for the help for those of you who offered it
