boost increase without boost controll
climaxsr20
Car: 1998 Silvia RedTop
hi guys. well i dont know but i put in my boost gauge and i took my car for a spin and i was running 14-15psi with out a boost control. did i do something wrong or is it okay for that to happen? i have talked to jeff from heavythrottle and he told me to just take all the pipes out and redo them. give me your opinions? thanks.
SpeedRacer1
Car: 1990 240SX, G35
When you run an open wastegate you will get extremely high boost. Check to see where you got the vac signal for the wastegate.
climaxsr20
i have the wastegate vac line plugged in right after the intake filter/maf
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
you need to hook the vaccum line up to a pressurized part of your piping. The hotpipe is a common source.
Luke
climaxsr20 wrote:i have the wastegate vac line plugged in right after the intake filter/maf
This should be hooked up after the turbo, like J-Spec said.
lee_harvey
Car: 93 nissan 240sr
yup
tubakins
Car: 89 240sx fastback
WORD!
D1 guy
Car: 1997 kouki S14 SR powered w/400whp and a stock 1994 FD R2 (26,000miles),
If your wastegate is hooked up, then it will run at what ever the spring weight is. If it isnt, the turbo will produce as much boost as it can. I know this bc my screw came out of the vac nipple on top of my wastegate and I denotated yesterday. If you have an external wastegate, that is.
