demonyoka420 wrote:Is there anything else that would cause this car to drive like this? I also notice it sounds differently when running better and the blow off valves are noticably louder. Any help would be appreciated. Just wanna know if theres anything else so i dont go replacing things that dont need to be replaced
Well according to what you just said earlier, you're running higher psi when its cold, so your BOV's would obviously be louder.
The piping, if old and weathered, can definately cause this when it gets warm (the fittings on the end expand when warm, causing a small leak to become a large leak). If the clutch booster is new, then it wouldn't likely be the cause of the vacuum problem (assuming there is one).
You can take the car to a nissan dealership and have them check the vacuum readings and see if they change as the car warms up.
